clogged cat
Old Jun 30, 2008 | 02:41 PM
cks's Avatar
cks
Member
Default clogged cat
i think my cat my be clogged is there any way to check this without bringing it into a shop.
Old Jun 30, 2008 | 03:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: clogged cat
If you bang on it and hear it rattle is one way. And if you have a Raytek or other brand digital thermometer the temp out of the cat should be like 50 degrees hotter than the inlet.Or you could wait until its dark out and get the truck up to temp and see if the cat. is glowing red.
Old Jun 30, 2008 | 04:04 PM
PartsChaser's Avatar
PartsChaser
What makes you think its clogged? Low/No power? Running hot?
When I thought mine was clogged, I unscrewed the front O2 sensor and fired it up and revved it up (before that it wouldnt go higher than 3k RPM or so)..
If it is clogged, best to replace or gut it.. get your power back!
