Seafoam
Old Jul 2, 2008 | 06:06 PM
sksemke's Avatar
sksemke
Default Seafoam
Can someone tell me where the brake bosster line is that I can use to suck seafoam into the engine? Thanks!!!
Old Jul 2, 2008 | 06:30 PM
Dodgeman000's Avatar
Dodgeman000
Default RE: Seafoam
Sea foam = Evil Clogs water jacket in engine
Old Jul 2, 2008 | 07:31 PM
Viper37's Avatar
Viper37
Default RE: Seafoam
Seafoam = the reason why my truck now gets 14mpg as opposed to 12.
Seafoam is bomb as ****.
Old Jul 2, 2008 | 10:25 PM
specialist484's Avatar
specialist484
Default RE: Seafoam
Seafoam... put it in all the holes. Love it
Old Jul 2, 2008 | 11:05 PM
94Beater's Avatar
94Beater
Default RE: Seafoam
Look at your brake booster. Its probably on the left hand side. Large rubber hose coming from the engine manifold to the booster.
Remember not to put all at once but little by little. This is very important as you might vapor lock your motor, bend some valves etc, etc.
Old Jul 2, 2008 | 11:28 PM
sksemke's Avatar
sksemke
Default RE: Seafoam
Man what a difference!!!! I put the whole can in and let it sit for a couple hours then started it and let it run at slightly higher RPM's than idle then took it for a drive. Runs much smoother now and doesnt act like its going to die when I put it in park!! Man I love this forum!! Thanks guys!!
Old Jul 2, 2008 | 11:30 PM
krs7272's Avatar
krs7272
Default RE: Seafoam
From Seafoams website
Step 1
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.)
Your engine is not direct port injected?
