BIG TIRES 315'S VS THE TRANNY
Old Jul 3, 2008 | 09:29 AM
ct.russ's Avatar
ct.russ
Default BIG TIRES 315'S VS THE TRANNY
DID THE LIFT . PUT THE BIGGER TIRES ON WITH THE IDEAS OF GETTIN THE PROGRAMMER .. HYPER TECH IS TELLING ME IF I DONT HAVE THE KELSEA HAYS ABS THEIRS WONT DO THE TIRE RECAL ... AND THATS WHAT IM MOST WANTING SO I CAN RESTORE THE SHIFT POINTS AND SPEEDO SO I DONT FRY THE TRANNY ... ANY ONE WITH INSITE'S ... THANKS RUSS
Old Jul 3, 2008 | 10:30 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: BIG TIRES 315'S VS THE TRANNY
I use a pp3 and when I ordered it a couple years ago that question never came up. HMM!
Old Jul 3, 2008 | 11:03 AM
globalwarmer01's Avatar
globalwarmer01
I bought the hypertech programer last month and it restored the speedo and shift points and i got 35's. Plus you can tell the difference on level one. It dumps a good amount of soot on level 2 and 3. I'm gonna get 33's because my 35's are rubbing the lower contol arm at full turn.
Old Jul 3, 2008 | 12:58 PM
hometheaterman's Avatar
hometheaterman
The Hypertech changed the speedo on that truck so I guess I have that brake thing. BTW I put in for a 33" tire and it was off. I ended up having to put in for like a 32.25" tire to get it to be right. So you might want to check it with a gps or something. It got it right just took some fiddling with.
Old Jul 3, 2008 | 05:06 PM
ct.russ's Avatar
ct.russ
i got the 98 5.2 not shure if this is the difference or not .. had a brain fart my fix couldnt be as easy as a speedo gear change could it ???
Old Jul 3, 2008 | 05:12 PM
ct.russ's Avatar
ct.russ
z man would you look at youre abs controler and see if you see and celsey hays anything on it ??
who makes the pp3 and do you like it alright
Old Jul 4, 2008 | 07:12 AM
zman17's Avatar
zman17
All thats on it is a sticker with some upc codes. And the PP3 is a Hypertech (Power Programer III)
Old Jul 4, 2008 | 08:38 AM
dhvaughan's Avatar
dhvaughan
i have a hypertech and it will not give me a prompt for the tire change.[:@] my brake controller does say kelsey hayes and has a bunch of part number stickers on it. i called hypertech and talked to an idiot. he didn't know anything and couldn't tell me why mine wouldn't prompt for tire size.
the kelsey hayes stamp is on the rear of the black plastic ABS case.
i started a thead to try and figure out a pattern to why the hypertech would sometimes not work, but didn't get enough good responses to identify anything.
https://dodgeforum.com/m_964619/tm.htm
forum members - if you will complete the questions below, it might help other members identify why this does/does not work. if you can provide details - it will be helpful. if you can't provide any details, then frankly - you are not contributing anything useful....
who are you - dhvaughan
year,drive - 2001 4wd
hypertech part # - 50006
hypertech rev - 06.16.22
brake controller - Kelsey Hayes
brake controller part number stickers
- sticker on rear P5201 0075 AD TXXBU 0791 A1154
- sticker on front C1H8MHQ 13451521-D
your ABS - REAR only. (vs all 4 wheel). if its all 4 wheel it will have a wire to the front hub tone ring
did it allow you to recalibrate speedo - NO
Old Jul 4, 2008 | 11:05 AM
ct.russ's Avatar
ct.russ
Old Jul 4, 2008 | 11:09 AM
ct.russ's Avatar
ct.russ
thanks for the numbers vaughan ill take em out to my truck see how well thay match up .... i dont seee any kelsey stamps on the case what so ever but i do have 3 4 upc codes .. i think my brake booster says bosh .. just tryin to figure this out .. hypertech tech guy did seem like a d!<k to me too ...
