Muffler/Exhaust Applications
Old Jul 4, 2008 | 02:44 PM
Sehr916's Avatar
Sehr916
Default Muffler/Exhaust Applications
Hey everyone, I was planning on getting a new muffler soon to put on the stock exhaust and was wondering about the stock application.
If I recall correctly its a 2.5" in and out but what about offset and muffler size? I'm planning on 50 series Flowmaster or maybe a Magnaflow
I have a: 2000 1500 5.9L in CA
Thank you!
Old Jul 4, 2008 | 02:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Muffler/Exhaust Applications
It should be straight in and out. The length is the only diiference.
Old Jul 4, 2008 | 05:14 PM
Sehr916's Avatar
Sehr916
Okay thanks!
Any suggestions on length of the aftermarket muffler I get? I don't know much about sizing.
Also, will clamping work fine for a while till I can get it welded?
Old Jul 4, 2008 | 05:23 PM
SilverRam_01's Avatar
SilverRam_01
it will if you clamp it tight, i ran my striahgtpipes like that for a few months, and i nevewr had any problems.
Old Jul 4, 2008 | 07:09 PM
Sehr916's Avatar
Sehr916
Thank you!
Would this one work?
50 Series Delta Flow
Old Jul 5, 2008 | 07:00 AM
zman17's Avatar
zman17
You should measure the inlet and outlet sizes so you don't have to use adapters.
Old Jul 5, 2008 | 07:25 AM
zman17's Avatar
zman17
I went to look up your stock exhaust to see what size the inlet and outlet is and they are 2 1/2". But, it looks like you need an offset muffler, not straight.
A 942553 is offset, whether or not its the right offset is hard to say.
Old Jul 5, 2008 | 03:02 PM
Sehr916's Avatar
Sehr916
Thanks again!
Would I need to just order the same offset as the stock muffler?
Old Jul 5, 2008 | 04:09 PM
zman17's Avatar
zman17
Yea but I couldn't find the specs anywhere.
