WTF no brakes!
Old Jul 7, 2008 | 11:21 PM
Redneck2345's Avatar
Redneck2345
Default RE: WTF no brakes!
no, when i was bringing it to the body shop the brakes went out and i figured it was just air in the lines, but it wasnt
drum brakes arent bad, little more than the fronts, but Ive done enough of them where i know my way around them
Old Jul 8, 2008 | 08:35 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Don't know what year your truck is and what, if any, ABS system it is equipped with, but if it does have ABS, make sure the dump valves aren't moving/leaking.
Old Jul 8, 2008 | 08:59 AM
zman17's Avatar
zman17
Retired Moderator - RIP
What do you mean the brake booster moves ? It's bolted to the firewall. And should not move.
Old Jul 8, 2008 | 10:09 AM
Redneck2345
when you step on the pedal it seems like it bulges out in the center, where the plunger unit would meet the master cylender
Rear Wheel ABS btw
Old Jul 8, 2008 | 11:41 AM
zman17's Avatar
zman17
So you are saying the MC moves too, or are you talking with it off? I'd say theres a prob cuz non of that should be moving. The steel brake line are going to break.
Old Jul 10, 2008 | 06:59 PM
zman17's Avatar
zman17
So is there any update to this problem ?
Old Jul 10, 2008 | 09:03 PM
Redneck2345
still working on it, gonna try the vacuum booster next i think. all i seem to be doing though is throwing cash at the truck and not getting any results
Old Jul 14, 2008 | 10:40 PM
Redneck2345
still working on it if any of you are wondering, I am totally lost with this thing. Kinda took a little break from it to work on some other things that needed repair, but I'll get it figured out, or bring it somewhere
Old Jul 15, 2008 | 08:28 AM
Sixtysixdeuce
A failed booster will give you an extremely stiff pedal. That's not your problem. Like I said, check the dump valve on your RABS unit. Should be the same Kelsey-Hayes garbage GM used for years, and they do fail.
Old Jul 17, 2008 | 05:52 PM
Redneck2345
ok....where is it....
