Runnin Stacks?
Old Jul 17, 2008 | 08:37 AM
iwhitne's Avatar
iwhitne
Default RE: Runnin Stacks?
do you think a cop is going to pull a person over that has stacks.. I'm mean that's just asing for an *** whoopin!
Old Jul 17, 2008 | 09:43 AM
talon6's Avatar
talon6
if you want a semi get your cdl's and start trucking. personally i think that stacks on a pick upare the stupidest thing ever. i wishthey would outlaw them everywhere.
EDIT....sorry i dont usually post things like that. i just get mad everytime i see a truck with stacks in the bed. especially the guy that lives across town with a stack on his v6ram.
Old Jul 17, 2008 | 01:05 PM
Silver_Dodge's Avatar
Silver_Dodge
What he might be talking about is how the new diesels have the particulate filter near the tip that burns off any soot in the exhaust so that there is no more black diesel smoke. You can't convert this type of system to stacks from what I recall. I doubt this applies to the older style exhaust systems.
Old Jul 20, 2008 | 04:34 AM
iwhitne's Avatar
iwhitne
i know this is stupid but.... has anyone put stacks on a gas engine? and if so do you gain any hp or mpg?
Old Jul 20, 2008 | 05:49 AM
talon6's Avatar
talon6
im thinking no back pressure. and you need some.
Old Jul 20, 2008 | 12:18 PM
motorbrreath's Avatar
motorbrreath
NEVER run stacks on a gas.
Old Jul 20, 2008 | 12:28 PM
Visious 318's Avatar
Visious 318
You can run stacks in any state but on the black smoke issue any desiel that blows black smoke is just wasting fuel and the black smoke is a resalt of the exsess deisel being burned in the exhuast manifold not in the cylander. This has been proved by Gail Banks.
[align=left] [/align]
Old Jul 20, 2008 | 09:53 PM
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: talon6
That's a common misconception. You do not need any back pressure, none, nada, zero. Long tube headers actually make a vacuum to help pull exhaust gasses out of the cylinder and reload it with a fresh A/F mixture. What you do need is exhaust velocity. You've got to get the exhaust pulses to clear the tail pipe before the next pulse hits it.
A common misunderstanding is that too big of a tail pipe hurts performance because there's no back pressure. What actually happens is the pipe expands too much and the gasses cool and slow down before they exit the tail pipe and cause turbulence and bottlenecking in the system. What you want is the right size of exhaust tubing to get the gasses out at the correct velocity not too small to cause backpressure, not to big to cause excessive cooling and lost velocity. As you build up an engine, you actually might gain performance by stepping up the size of your exhaust system. I saw a chart somewhere that had recommendations for exhaust diameter based on what HP you were making at the crank. Something along the lines of 1/2" increase for every 100hp made over stock.
Another good way to keep velocity and improve system scavenging is to have the entire exhaust system ceramic coated inside and out. It isn't cheap, but it'll net you some gains over a plain system.
Old Jul 21, 2008 | 12:03 AM
talon6's Avatar
talon6
gotcha. i wish i had just some of the knowlege some of you guys do on here.
Old Jul 22, 2008 | 04:08 PM
lastrights's Avatar
lastrights
http://www.youtube.com/watch?v=Y9R1U...eature=relateda guy on you tube with 5.2 liter gas engine, it sounds pretty badass, couldent amagine how it would sound with a 5.9 with headers and cat lol
