knocking noise/feel knock on floor boards
Old Jul 12, 2008 | 12:21 PM
robinbobin's Avatar
robinbobin
Default knocking noise/feel knock on floor boards
hi, ive got this knocking noise that i hear right under me and i can feel on my feet when i hit bumps/pot holes, i cant figure it out for the life of me. and its both passenger and driver side.Any ideas? Maybe control arm bushings
1999 ram
4x4 quad cab
5.9
thanks for the help
Old Jul 12, 2008 | 04:04 PM
Shawn86's Avatar
Shawn86
Default RE: knocking noise/feel knock on floor boards
Check your lower shock mounting bolts, they'll sometimes come loose
Old Jul 12, 2008 | 04:43 PM
dhvaughan's Avatar
dhvaughan
+1 lower shock bolts. tighten to 100 lbs torque. that takes a big *** pull bar, pipe, or air gun.
Old Jul 12, 2008 | 05:30 PM
robinbobin's Avatar
robinbobin
alrighty then ill be checking them in a bit here, ill let you guys know. Really appreciate the input/help
Old Jul 12, 2008 | 09:21 PM
TheForce55555's Avatar
TheForce55555
Mine made that same noise for like 2 years and I finally replaced the front shocks and the noise went away
Old Jul 13, 2008 | 12:15 AM
steve05ram360's Avatar
steve05ram360
you might also want to check the upper control arm bushing... if your feeling it on the floor board then the CA is the only thing in that area. my '05 does it as well and I know my CA bushings are shot.
Old Jul 16, 2008 | 07:31 PM
jacksonram's Avatar
jacksonram
New Member
Check the inner fender liner on both sides. They will become loose over time. worked for me
& a buddy of mine.
