POP
Old Jul 14, 2008 | 11:06 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Default RE: POP
Have you checked the front wheel bearings?
Old Jul 14, 2008 | 11:28 AM
greenmachine's Avatar
greenmachine
Default RE: POP
I have been all over the front end. The front wheels have nobearingplay. Dont quite understand the power steering suggestion?! I do not have a lift. I have never payed attention while in reverse. Wether I drive straight or turn there is that pop when the brakes are applied. No pop just turning the wheels. I can also feel it in the brake pedal not just the column.
Old Jul 14, 2008 | 07:52 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: POP
That "POP" sound you hear happens when you run over Kia Rios and Honda Fits. Other than that sound as you crush them, you would never know.
From dodgeram.org:
Steering Wheel Clunk - More of a thump that is felt than it is heard [ul][*]TSB 19-08-97 replace intermediate shaft[*]TSB 19-13-97 replace steering column toe plate cover[*]A brake pedal rattle can telegraph to the steering wheel - common [ul][*]TSB 05-08-96. install a spring washer at pivot[/ul][*]Loose intermediate steering shaft couplings - make sure the bolt is tight![*]Loose intermediate shaft slip joint [ul][*]Inserting tie wraps into slip joint reduces the clunk.[*]Borgeson replacement steering shaft - installation instructions and photos[*]Flaming River replacement steering shaft[/ul] [/ul]Exact Source: http://dodgeram.org/tech/troubleshoot/steering.htm
Old Jul 14, 2008 | 11:13 PM
dodge@1997's Avatar
dodge@1997
Default RE: POP
I will dif be looking in to this if my ram does not sreet better after the new track bar.
Old Jul 15, 2008 | 12:10 PM
DPR250R's Avatar
DPR250R
Default RE: POP
ORIGINAL: dodge@1997
Some of the noise may be coming from the little kid you have in the bed of your truck bouncing around!! JK..
I just ordered the steering column bushing for my truck.... will report back...
