98 Ram 5.9 misfire
Old Jul 17, 2008 | 03:46 PM
Dodgeman282000's Avatar
Dodgeman282000
New Member
Default 98 Ram 5.9 misfire
I have a '98 ram 1500 4x4 with a 360. I bought it 5 yrs ago with 30k miles on it. As with all my cars I did a tune-up when I got it. All went well exept #8 plug was hard to get out. Every 30k miles arfter that I've had to do a tune-up for random misfire problems. At 185k miles it has gotten worse. It now runs rich as well. It runs smooth onlt on the hiway @ 75mph with no load. I changed the O2 sensors (2 of them). And 2 injectors (#1 & 2). My scaner is no real help either. I'm open to any ideas on where to look now.
[IMG]local://upfiles/93144/12EC85C95FAF483F849FD2A2616887DD.jpg[/IMG]
Old Jul 17, 2008 | 06:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: 98 Ram 5.9 misfire
Check the plenum gasket. And do a search here for how to route the spark plug wires.
Old Jul 18, 2008 | 08:00 AM
Dodgeman282000
New Member
Is there a way to check it with out pulling the intake?
Old Jul 18, 2008 | 11:00 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
I have this exact same problem. I believe I may have a cracked head on #8. Have you run a full compression test yet?
Old Jul 18, 2008 | 11:52 AM
Matt Harwood's Avatar
Matt Harwood
Mine persistently had this problem for 10,000 miles off and on. The re-route TSB cured it when plugs, wires, cap, rotor, distributor and O2 sensors didn't. It's free and doesn't hurt to try.
Hope this helps.
Old Jul 18, 2008 | 03:51 PM
PartsChaser's Avatar
PartsChaser
+1 on trying to re-route your plug wires. I had the same issue, right around 185k also on mine, after trying all the over the counter remedies, I ended up running a compression test and found out that #5 cylinder had a bent exhaust valve. Cheap and easy to try, might be time for a new set of heads! haha
Old Jul 18, 2008 | 04:43 PM
zman17's Avatar
zman17
And as far as checking the plenum goes, just remove the air cleaner , open the butterflies and look into the intake with a flashlight and see if you have oil pooling .
