bigger injectors ?
Old Jul 20, 2008 | 01:00 AM
talon6's Avatar
talon6
Default bigger injectors ?
if i was to get lets say 24lb injectors would i notice much of a hp gain? and would i need a bigger fuel pump,or other mods? and if everything is a go which ones do you guys recommend? what are the stockers rated?
Old Jul 20, 2008 | 07:02 PM
talon6's Avatar
talon6
Default RE: bigger injectors ?
bump
Old Jul 20, 2008 | 09:10 PM
xskylinedx's Avatar
xskylinedx
You already have 23.2lb injectors from the factory, I think you could easily find something else for the money that will help in the power department. Heres a little tool to help you calculate what you need for injector size.
HP(crank)/ # of cyl/ .80 (max duty cycle 80%)* BSFC = Injector size
BSFC for a N/A motor is: .45 - .50 (BSFC is Brake Specific Fuel Consumption)
BSFC for a F/I motor is : .55 - .60
So lets say you have 265hp.
265 / 8 / .80 * .50 = 20.7
So even at a slightly higher hp rating than factory you still have more injector than you need. It would take about 300 crank hp to exceed the factory injectors.
Old Jul 20, 2008 | 09:54 PM
aim4squirrels's Avatar
aim4squirrels
On a stock engine with a stock PCM all you'll do is waste gas with bigger injectors.
Old Jul 20, 2008 | 11:59 PM
talon6's Avatar
talon6
thank you. i guess i will be looking for something else to boost hp.
