code check engine problem
Old Jul 22, 2008 | 06:11 PM
mfrump's Avatar
mfrump
Default code check engine problem
i have a 200 ram 1500 4x4 318 i have a hypertech power programmer 111 for this truck and after putting everything back to stock as far as the programming i got a check engine light and i pulled the code and it was a p0601 wich is a pcu fail issue, but the truck is running fine not sure what to do
Old Jul 22, 2008 | 06:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: code check engine problem
Try disconnecting the neg. bat. cable for a few minutes and let the PCM reset itself.
Old Jul 23, 2008 | 01:28 AM
mfrump's Avatar
mfrump
well i tried the pos cable and let it sit for like 10 min and it went off then came right back on after the 2nd start
