electrical problem
Old Jan 26, 2005 | 02:15 PM
snipercole's Avatar
snipercole
Default electrical problem
I recently bought a used ram 1500 and had some problem with the speakers. I pulled the aftermarket CD player out of the dash and now I have no constant power to the CD, no dome light, and no power to the computer port. If i connect the constant and switched power to the CD it will work when the key is on but it has no memory. I have checked all the fuse in the fuse panel and they are all good. Anyone know where I might look to find my problem?
Thanks
Gene Cole III
Old Jan 26, 2005 | 07:43 PM
P.B.'s Avatar
P.B.
Default RE: electrical problem
yES. iNSTALLING STEREO'S i HAVE COME ACCROS THIS ALL THE TIME. cHECK TO SEE IF YOU HAVE A FUSE BOX UNDER THE HOOD. mORE THAN LIKELY ALL THE FUSES WITH CONSTANT POWER ARE THERE. GOOD LUCK AND LET ME KNOW HOW YOU MAKE OUT.
