Finally found a mopar pcm
Old Jul 31, 2008 | 12:51 AM
95 Jamin Ram's Avatar
95 Jamin Ram
Default Finally found a mopar pcm
For a 1995 but now i kind of dont want it because you have to use premium its brand new never taken out of the box. Are these things worth it? Have any of you guys tried not using premium?
Old Jul 31, 2008 | 01:02 AM
95 Jamin Ram
Default RE: Finally found a mopar pcm
Also does 94-95 also get the pelenium leak i think they do but not sure. No sign's of it other then the catalytic converter
Old Jul 31, 2008 | 11:37 AM
aim4squirrels's Avatar
aim4squirrels
how much did you pay for the mopar PCM? And yes, all 2nd gens get the plenum leak problem. That should be high on the list of fixes if you have the problem and haven't yet fixed it.
Old Jul 31, 2008 | 11:40 AM
talon6's Avatar
talon6
all do? 55k no leak yet.maybe i should just do it before it even happens.
Old Jul 31, 2008 | 02:45 PM
95 Jamin Ram
the pcm is $230 but i didnt buy it yet, dont know if i wanna buy premium all the time. But if the truck needs the pelnium then that what ill have to get. What are some sign's of a pelnium leak? i know i can take off the throttle body to look but when the oil is changed never noticed a difference in that
Old Jul 31, 2008 | 02:48 PM
95 Jamin Ram
anyone use the performance pcm without the premium fuel? Also do you really notice the gains?
Old Jul 31, 2008 | 09:19 PM
aim4squirrels
Remove the airhat and TB and look down into the intake manifold. If you see pooling oil, you have the leak.
Old Jul 31, 2008 | 09:34 PM
lastrights's Avatar
lastrights
i just heard the leak is really bad, you lose alot of milage and performance, i myself havent had it yet and i have 126xxx miles on her , i heard there is a plenum mod, that actually give you more power ,some guys will tell us whats up about it ??? anyone ??? chime in
Old Aug 1, 2008 | 12:21 AM
95 Jamin Ram
i know what your talking about modding the kegger mod cut down the runner's and take out the center divider. I havent checked yet but should it have a little as long as no pooling. But if there is a little that means its starting?
