prove him wrong
Old Aug 2, 2008 | 02:32 AM
chadram98's Avatar
chadram98
Default prove him wrong
my friend says his stock 93 ford with a 4.9 i-l can out pull my 98 ram with a 360 3:73 gearsand dana axles
Old Aug 2, 2008 | 07:49 AM
98DodgeRam1500's Avatar
98DodgeRam1500
Default RE: prove him wrong
in less time it took you to sign up on the DF, you could have googled your answer.
http://www.ford-trucks.com/forums/15...tml#post971684
4.9L with Auto and 3.55 can tow up to 5500lbs.
But he might be able to out run you!
Old Aug 2, 2008 | 10:52 AM
jasonw's Avatar
jasonw
Site Moderator
What kind of modifications or upgrades has he made?
Old Aug 2, 2008 | 02:07 PM
xskylinedx's Avatar
xskylinedx
From what I've found his truckisrated at5300lbs and yours is rated at 5200lbs. But your truck has 100 more hp and 80 more lb-ft of torque. I've got a 2001 5.9 and its rated for 7150lbs for towing. I know they upgraded the brakes in 2000 so maybe your brake capacity is all thats holding you back on tow capacity. Can anyone else chime in on this?
Old Aug 3, 2008 | 01:55 AM
motorbrreath's Avatar
motorbrreath
why not just see for your self and actually hook em up...
Old Aug 3, 2008 | 04:00 AM
jasonw's Avatar
jasonw
Site Moderator
ORIGINAL: motorbrreath
+1.
Old Aug 3, 2008 | 02:36 PM
xskylinedx's Avatar
xskylinedx
f-it your right guys, just hook'em up. yank that 8.8 right out from under him. my buddy at work (whos a die hard ford fan)has one of those with a v8 and he wouldn't hook up to me.
Old Aug 3, 2008 | 07:58 PM
Major Trouble's Avatar
Major Trouble
make sure you got good tires and traction or its lights out for you
Old Aug 3, 2008 | 11:04 PM
Visious 318's Avatar
Visious 318
If it was my dodge it would be lights out if it hooked up to a chevette my turd can't pull or even think of turning the tires over all it does is bog and not due little of anything till 2600rpm
[align=left] [/align]
Old Aug 4, 2008 | 01:30 AM
motorbrreath
i know one thing, when someone talks **** about wantin to pull, then pull.
