oil presser and tem problem
Old Aug 2, 2008 | 03:00 PM
dodgeboy7's Avatar
dodgeboy7
Default oil presser and tem problem
ihav a 97 ram with 90,000 miles. My oil light keeps coming on and the oil presser keeps droping or sit at 0 and my oil tem at 210 just drive down my road. Is my oil pump going? I put a new oil presser send unit or what ever you want to call it. i really need help. i think my motor done. It still starts and drives up just not the same for some reason.
Old Aug 2, 2008 | 11:00 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Default RE: oil presser and tem problem
get a mechanical pump on it. double check everything. 210 might not be that bad for internal temp. an if it is bad oil pressure dont drive till a new oil pump is in an the bearing are double checked.. thats the safest bet in my opinion.
Old Aug 3, 2008 | 12:10 AM
Ramsrush's Avatar
Ramsrush
Could be many things.Buddy of mine had the same problem once. It turned out to be a faulty FRAM oil filter.
Old Aug 3, 2008 | 04:06 AM
jasonw's Avatar
jasonw
Site Moderator
FRAM is absolute garbage.
