Tune up?
Old Aug 5, 2008 | 11:11 AM
  #21
95 Jamin Ram's Avatar
95 Jamin Ram
I should feel some type of difference 95 with 120,000 never did a tune up
Old Aug 5, 2008 | 11:54 AM
  #22
talon6's Avatar
talon6
wow 120,000 and no tune up? wow! you should be a little more happy with power and mpg after it.
Old Aug 5, 2008 | 12:18 PM
  #23
hometheaterman's Avatar
hometheaterman
I had probably 60k or so on my truck and not sure if it had ever had a tune up when I did the first one. Then I did another one at 99k or so.
I did wait a long time on our 96 Honda and it did seem to help some when I did a tune up.
Old Aug 5, 2008 | 04:19 PM
  #24
sk8ordie's Avatar
sk8ordie
i just did mine and i used borg warner cap and rotor. MSD streetfire wires they were 8mm and only $40 @ checker. i have 128,000 on mine bought w/ 125000. and i dont know how my truck ran! the cap and rotor were completely burnt! she runs MUCH better now. 95 jammin ram i would suggest changing the coil also if you dont know when the last time it was changed. plus with the milage you have.
Old Aug 5, 2008 | 05:26 PM
  #25
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by hometheaterman
For a cap and rotor I'd just get a cap with brass terminals. The Napa ones seems to be a good choice. I've also heard of some liking the OEM and saying it lasts the best but I'm not sure if it's got brass terminals or not.
Its not. The stock/OEM units are aluminum terminals. Brass resists corrosion much better than aluminum.
There is a reason back during the days of ancient Rome and the Roman Empire that the Greek phalanx units used brass ends on the back of their long spears. They could plant it in the ground to hold their enemy at bay with the other end, and it wouldn't rust like iron.
Old Aug 5, 2008 | 06:28 PM
  #26
hometheaterman
Oh okay. I just knew one of the guys on here said he had the best luck with the stock ones lasting the longest but none lasted long with his MSD setup. I think it was steve something that has a 3rd gen now.
Old Aug 5, 2008 | 07:37 PM
  #27
aim4squirrels's Avatar
aim4squirrels
I would think corrosion should be a non-issue if you use dielectric grease.
and steve05ram360 was referring to the mopar performance cap and rotor that lasted longer with his MSD Offroad 6a box, not the generic mopar cap.
