AC Compressor cuts out after 15-20 minutes. Any ideas why?
Old Aug 4, 2008 | 02:08 AM
Vincep's Avatar
Vincep
Default AC Compressor cuts out after 15-20 minutes. Any ideas why?
My clutch stops spinning after 15-20 minutes. WhenI let the truck set for a half hour, the process repeats.
My ac is fully charged andI installed a brand new relay. The compresor seems to spin freely with no "bad noise".Any ideas what could be the possible cause of this. Thanks.
Old Aug 4, 2008 | 04:09 AM
jasonw's Avatar
jasonw
Site Moderator
Default RE: AC Compressor cuts out after 15-20 minutes. Any ideas why?
I always thought the clutch was supposed to spin for a bit and then quit for a bit and then spin again, and so on, when the truck isn't moving.
Old Aug 4, 2008 | 08:54 AM
aim4squirrels's Avatar
aim4squirrels
does the ac stop cooling?
Old Aug 4, 2008 | 12:11 PM
nim81's Avatar
nim81
could be your low pressure switch mine was doing the same thing here a link to my fix
https://dodgeforum.com/m_1338933/tm.htm
Old Aug 4, 2008 | 12:35 PM
Vincep's Avatar
Vincep
The truck does stop cooling when the clutch stops spinning.
Old Aug 4, 2008 | 12:42 PM
LJ's Avatar
LJ
Mine was a sensor in the Condensing Box. I guess it would freeze up, telling the A/C to stop working until the sensor thawedout. You'd be driving and all of a sudden the Air flow would change, and the cab would fill with hot humid air. talk about irritating. The dealer relocated the sensor and it seems the problem has not returned. 03' 2500 CTD HO.
Old Aug 5, 2008 | 12:02 AM
dodgeguy97's Avatar
dodgeguy97
could be your blower resistor under the dash sounds more like your pressure switch mounted on thr dryer reciever.
Old Aug 5, 2008 | 12:19 AM
Visious 318's Avatar
Visious 318
What are your pressure readings on the high side and low side lines?
It may be a pluged up orface tube, or condecer. If this is the case it could damage you a/c pump and other related parts.
