Engine swap 3.9 to 5.2
I have a 01 dodge ram 1500 single cab. I have a 3.9 in it right now im not happy with the performance so i bought the 5.2 out of a wrecked 01. What parts will i need to do the swap just a computer?? I heard maybe a new torque converter but then i heard it will be fine. Any help would be nice thanks guys. Let me know.
The 5.2 will bolt up to the 3.9 trans. Get the engine and frame mounts, computer and wiring harness from the wrecked truck. Now bolt everything in and change the computer and wiring and you are all set. The 42's were behind 5.2's change the fluid and adjust the bands it will be ok.
uh... the 3.9 trans is not gonna hold up under the 5.2's power. You need the trans, computer, wireing harness and all engine/vaccum lines. Its alot of work. Prolly need to check on the fuel lines as well.
the 3.9 trans is a a500, the 5.2 is an a518.
http://mopartransmission.com/searchb...=34&Submit.y=7
Motorbrreath is right. The 3.9L had the 42RE (A500) transmission, the 5.2L and 5.9L had the 46RE (A518) transmission. If the 5.2L bolted up to the A500, which is doubtful, I agree with Motorbrreath and highly doubt it would hold up to the 5.2L.
