tow rating question
Old Aug 5, 2008 | 12:24 PM
2xroamer's Avatar
2xroamer
Junior Member
Default tow rating question
I had no idea this would be such a tough questions to answer...even the Dodge.com corporate web site and email contact didn't help. So here it goes, and I hope someone here can help me.
I have a 1996 Ram 3500 dually, 3.55 rear end with V10 and automatic trans. What are my tow ratings for this vehicle?
I'm thinking about pulling a smaller 5er or travel trailer with this truck, but I'm having some difficulty with getting the ratings associated with towing. Please help Dodge Forum!!
Thanks in advance for your help.
2x
Old Aug 5, 2008 | 01:03 PM
1980blackfiveoh's Avatar
1980blackfiveoh
My 2500 V10 4x4 qc is 13500 lbs, so if you ram is a 2x4 your rating would well above that. I tow a 31' 12000 lbs 5th wheel which I would consider quite large. Also keep in mind a lot of states and provinces require special licenses to tow anything over 10 000 lbs. I would try and stay under the 10 000 lbs mark but I think your ram is at least
13500 lbs. I found my tow rating in my manual so have a look for a manual for a 96.
Old Aug 6, 2008 | 07:12 AM
2xroamer's Avatar
2xroamer
Junior Member
Thanks 5-O, that's good info. I bought the truck used a number of years ago, and didn't get the owners manual. The truck was repainted since, and it appears that the door jam sticker with the info was removed. My truck is a 2x4, and it's a club cab. I've seen a range of results previously, ranging from 10K to 13,800, which is a wide range when you're looking at trailers between 28 and 33 foot long.
So if there are any 1996 3500 owners out there with a manual, please help me to clear this up. Thanks again for your help.
Old Aug 6, 2008 | 04:09 PM
dillonjm's Avatar
dillonjm
Here are the specs for an 01, probably won't be exactly the same as a 96, but shouldn't be too far off.
http://dodgeram.info/2001/towing-charts.html
Old Aug 7, 2008 | 07:27 AM
2xroamer's Avatar
2xroamer
Junior Member
Thanks for the input. Slowly but surely I'll be able to narrow this down. Trailer Life's archives went to '99, where the max trailer rating is 13,400. Here's the link if anyone is interested:
http://www.trailerlife.com/downloads/99towingguide.pdf
I've heard everything from 10K to 13,800, and I want to be very careful not to overload. At the same time I'm selfish, I want to get a trailer with some space and creature comforts, so going smaller doesn't fit the bill for me and the family. So thanks again for your help!
Any input is appreciated!
Old Aug 7, 2008 | 08:38 AM
sawtooth's Avatar
sawtooth
Default '96 Ram owners manual
I-Model 3500 GVWR=10,500.
A-8.0L(V10) Trans.= all. Axel Ratio=all. GCWR=19,000. Max Trailer Wt.=13,200.
II-Model 3500 (4-Wheel Drive) GVWR=10,500.
B--8.0L(V10) Trans.= all. Axel Ratio=all. GCWR=19,000. Max Trailer Wt.=12,800.
III-Model 3500
A-Max Trailer Tongue Weight=1200.
GCWR-total truck, trailer, cargo, people % fluids.
GTW-Gross trailer weight.
With ClassIV hitch, you can tow a trailer with a GTW of up to 10,000 lbs.
Old Aug 7, 2008 | 10:36 AM
charlie1935's Avatar
charlie1935
Thumbs up
III-Model 3500
I see sawtooth must have looked in the owners manual also.
Exactly right word for word.
Old Aug 7, 2008 | 03:07 PM
2xroamer's Avatar
2xroamer
Junior Member
Thank you all!! Greatly appreciated...
