changed brakes now soft pedal
Old Aug 7, 2008 | 12:52 PM
joshb's Avatar
joshb
Default changed brakes now soft pedal
I changed my front pads and rotors this morning and now i can't get them to pump up. They will pump up when the truck is off but as soon as I crank it, the pedal goes away. Any suggestions?
Old Aug 7, 2008 | 02:10 PM
EricCartman's Avatar
EricCartman
Did you push any break fluid out of the resiviour when you compressed the calipers? I would double check the resiviour adn see if you need to add fluid.
That might help... but to be on the safe side of things... I would bleed your brakes. Start with the furtherst brake (rear passenger) and start workinging your way to the closest (front driver).
Cartman
MEINEKEMAN1's Avatar
MEINEKEMAN1
Did you open the hydraulic system at all?
