New & Needing Help
Old Aug 7, 2008 | 04:07 PM
phoenixrising's Avatar
phoenixrising
Junior Member
Question New & Needing Help
We have a Dodge Ram 2500 that has just started leaking water into the cab. Maybe this is a dumb question. My husband is out of town and I wanted to see if it could be a quick fix. It's leaking from what appears to be a plastic a/c vent and it leaks on both sides. If I'm driving around a sharp curve, it pours out. The water is freezing cold... don't know if that information is needed or not but it is very cold water. It comes out in spurts. It will be nothing for a little bit and then pour out at once. It just started doing it this past weekend and I'm at a loss. I was thinking maybe a drain hose was clogged? Don't know where to look. Any help would be GREATLY appreciated.
Old Aug 7, 2008 | 04:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
It would help if you posted up the year of the truck. Sometimes there are subtle differences that affect the answer to be given.
Old Aug 7, 2008 | 04:27 PM
phoenixrising
Junior Member
Ah, okay, it's a 1996 Dodge Ram extended cab long wheel base v8 engine. Thank you for letting me know!
Old Aug 7, 2008 | 04:57 PM
dhvaughan's Avatar
dhvaughan
open the hood and look on the passenger side firewall, down sort of low, and just under the computer. find the ac condensation drain tube. its about 1/4 - 3/8" diameter and sticks out about 1/4" or so. fish a piece of wire up in there and wiggle it around. hopefully a bunch of crap will come out.
