RPM's fluctuate while idleing
Old Aug 7, 2008 | 11:51 PM
wingmaninmo's Avatar
wingmaninmo
Junior Member
Default RPM's fluctuate while idleing
Hey everybody. Have had a 2000 Dodge 2500 4x4 for the last five years and have been very happy with it. Very little problems. I am experiencing an issue currently where the RPM's are fluctuating between 1200 and 2000 while idling. It does it in park, nuetral, drive. No problems while moving, just when sitting at idle. I used the ignition on/off/on/off/on and it shows p donE whatever that means. Any ideas on what could be the issue? Thanks in advance.
Old Aug 8, 2008 | 12:24 AM
pro_onSNOW's Avatar
pro_onSNOW
Sounds like you could have a vacume leak.
Old Aug 8, 2008 | 01:47 PM
wingmaninmo
Junior Member
spend about a 1/2 hour searching the site and then went and switched out the IAC. seemed to do the trick. this is a great site. thanks.
Old Aug 8, 2008 | 06:15 PM
dhvaughan's Avatar
dhvaughan
good. iac is responsible for the idle, and its a trouble prone little sob.
Old Aug 11, 2008 | 09:25 PM
Ram2K1's Avatar
Ram2K1
Yeah, little things like that can drive you crazy. I thought my tranny was slipping, and it was my TPS.
