how much mpg would i increase with these parts
Old Aug 12, 2008 | 06:55 AM
motorbrreath's Avatar
motorbrreath
Originally Posted by jason.w
Or you could get one of these...
http://cgi.ebay.com/ebaymotors/REAL-...spagenameZWDVW
If its too good to be true, it is.
uh... yeah thats a scam.
Old Aug 12, 2008 | 07:56 AM
aim4squirrels's Avatar
aim4squirrels
I don't know man, +100HP and 30MPG sounds pretty sweet. I may have to give it a shot...
Old Aug 12, 2008 | 10:54 AM
HankL's Avatar
HankL
Originally Posted by murph111
There are a couple of simple modifications you will need as well with this system, o2 extender, Map/Maf adjuster, EFIE enhancer and posibbly an o2 adjuster for the gains to really be seen. You could also build your own circuits and generator if you are handy.
If you have those electronic devices
then you don't need the bogus HHO generator
... you can simply illegally violate the EPA NOx pollution rules
by leaning the air to fuel ratio
and get 10 to 30% better fuel economy:
http://www.designnews.com/article/97..._Lean_Burn.php
this relatively cheap device from Australia
is handy for modifying sensor signals
of either the O2 sensor, MAP, MAF, IAT
http://autospeed.com/cms/A_2420/article.html
It could be used to modify the 0 to 5 volt signal coming from a wide range O2 sensor to mimic the 0 to 1 volt signal of a narrow band O2 sensor that your factory Dodge PCM computer expects to see
