Death Flash fixed and vacuum no longer an issue
Old Aug 14, 2008 | 01:26 PM
Mowhawk's Avatar
Mowhawk
And in the mean time, think of what you could do with that vaseline for an hour while you wait. O.o
Old Aug 14, 2008 | 01:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
SICKO!
Old Aug 14, 2008 | 01:46 PM
Mowhawk's Avatar
Mowhawk
What, you could do your tires too. Im the sicko? Someone elses mind seems to be in the gutter
Old Aug 14, 2008 | 03:42 PM
steve05ram360's Avatar
steve05ram360
lmao....
Old Aug 14, 2008 | 03:58 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
And that's a problem -- how?
Old Aug 14, 2008 | 09:53 PM
Mowhawk's Avatar
Mowhawk
oh theres no problem, just wanna make it clear im not the only one with mind in the gutter lol
Old Aug 15, 2008 | 08:21 AM
HankL's Avatar
HankL
Back to the original question:
Ignition timing does affect engine vacuum.
In the old days of the 1960s on carb engines before pollution controls
we commonly used to set engine idle ignition timing
by watching vacuum gauge level at idle
and 'peaking' the vacuum with the ignition timing.
At any part throttle engine operation where the load is held constant
the vacuum level will go higher
if the ignition timing is brought closer to 'Mean Best Torque' setting.
If the load is not held constant
but the throttle opening position is held constant instead
then as the ignition timing is improved
the rpm of the engine will go up as the torque goes up
as the vacuum level stays about the same.
Old Aug 20, 2008 | 04:49 PM
arcsum68's Avatar
arcsum68
Some good info there, never heard about the Vaseline thing, good thing to know.
Hank, thank you as well, very detailed.
Old Nov 16, 2008 | 09:26 PM
thunderz's Avatar
thunderz
Default DF
What is the death flash?
Old Nov 16, 2008 | 09:39 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by VWandDodge
Yep. Believe it or not, the best thing to use is a jar of Vaseline. The petroleum is absorbed into the surface. Apply and let sit for an hour or so and then wipe clean.
ok, i applied the vaseline to the part in question and then wiped it clean (rapidly, about 100 times).
now what do i do with the other 58 minutes.
