whats the difference
Old Aug 18, 2008 | 09:01 PM
tboss's Avatar
tboss
Default whats the difference
How is a 1500 ram differant from a 2500 ram Is is size weight engine size or what. Im thinking abt buying a camping trailor that weighs abt 6000 lbs and I want to know am I gonna be crowding my 5.9 1500 or not. The camper is a 5th wheel. My ram is a 1996 with 180000miles. With 17 inch wheels.H Has anyone here ever done this and how good did she preform with that much weight. Tks Terry
Old Aug 18, 2008 | 10:42 PM
dhvaughan's Avatar
dhvaughan
everything. 2500 has dana 60 front and rear axles, which are much stouter than dana 44 and chrysler 9.25. also bigger brakes, i think a heavier transmission, re/rh 47 instead of re/rh46. stouter t-case, springs, etc, etc. i'm guessing some here, but i think engine choice on 2500 included diesel, v10 gas, v8-360. i think your 1500 will pull the trailer mostly ok. you may want some heavier rear springs if you get a lot of rear end squat. stopping may be a challenge. transmission is a weak point. if you've got a heavy duty bulletproof version you'll be ok. you'll definitely want a big cooler. stock trans probably won't last.
Old Aug 18, 2008 | 10:56 PM
Visious 318's Avatar
Visious 318
I know the V10 has more power and torque than the V8's and a trailer like that will take 3/4 to a mile to get to 70mph. Personally i wouldn't pull a Dodge with a Slip-o-matic all you will ever do is blow the tranny up I know even the 12v cummins trannys don't stand up to pullin very long unless you have a stick that has allready been rebuilt. I have even installed the "Bullet Proof" Trannys to see 3 fail in less than one week. We finnally found a company thats makes a adaptor kit to go cummins to 4L80E/Allison six speed never had another issue.
