terrible squeak
Old Aug 22, 2008 | 02:02 PM
DR360V8's Avatar
DR360V8
Default terrible squeak
from the steering or suspension idk. but i hit all the grease points i could find(5) and water came out 3 but its still there , very loud when i turn the wheel back and forth and sometimes when you get in, i can make a video if needed
Old Aug 22, 2008 | 02:40 PM
Sehr916's Avatar
Sehr916
I had a loud squeak a while back when the truck moved that ended up being the driveshaft u-joints
Old Aug 22, 2008 | 07:13 PM
jasonw's Avatar
jasonw
Site Moderator
Does it squeak all the time, just when you turn, or ... ?
From the sound of your post, it does it mostly only when you turn the wheel, especially at a stop/low speeds. When that happened to mine, turned out to be needing new u-joints.
Old Aug 22, 2008 | 07:33 PM
MEINEKEMAN1's Avatar
MEINEKEMAN1
Does it squeek while you are driving only or even at idle when turning the wheel?
Old Aug 22, 2008 | 08:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds like belt is stretched or idler pulley bearing is bad.Or the tensioner.
Old Aug 26, 2008 | 10:18 PM
DR360V8's Avatar
DR360V8
the ball joints are being replaced tommorow as i am told that is the problem and seeing the rubber surround is shreaded on them, getting both sides done for 650$ and a free brakes change(supposedly free) others were telling my dad its at least a 1000$ job
Old Aug 26, 2008 | 10:19 PM
DR360V8's Avatar
DR360V8
it squeaks when i turn and suspension goes up and down from jumping or bumps
