High idle
Old Aug 22, 2008 | 09:00 PM
meanwhitemopar's Avatar
meanwhitemopar
Exclamation High idle
I was doing a little bit of hardball trial riding and my battery tie down wasnt tight so after all the bumps and road driving when i hit good ditch, my battery knocked over and hit my belts, i knew something had happen because i heard the thud, so i stoped poped the hood put my battery back on the tray ( with the truck off) put the tie down back on it and closed the hood, started it back up and now the idle in drive at a stop is like 1100 rpm and when in park, around 12 to 1300, i took it to the cr wash, figuered something got wet and muddy, so i washed off the engine bay, still does it. the truck itself doesnt react to anything differantly, just the idle, is this the TPS or is it something that can just be easily fixed?
Old Aug 22, 2008 | 09:49 PM
Mark Benson's Avatar
Mark Benson
Have you checked for any loose vacumm lines?
Old Aug 22, 2008 | 10:42 PM
meanwhitemopar
to be honset, i have a very good mechanical score for the militry, i am all hands on, but i dont even know where to start, i took my intake completely off, and found sediment of mud in there, so thats not good, but what other lines could it be? theres also a few electrical things hooked in, what is what?
Old Aug 23, 2008 | 03:21 AM
Mudbone25's Avatar
Mudbone25
id start with TPS and IAC. Do you notice the rpms drop the second you touch the pedal? if so id say its the TPS. when the battery knocked over it could of yanked at a wire. You can clean the TPS with electrical cleaner. Drill a small hole in the body of the sensor and spray it with cleaner then seal it up with silacone.
Old Aug 23, 2008 | 10:48 AM
meanwhitemopar
Originally Posted by Mudbone25
when the battery knocked over it could of yanked at a wire. .
it did yank something, just not wires, it was the cruise control cable, pintched it and didnt allow the throttle butterflys to fully close, causeing high idle, got it fix for now, just have to get my new cable, but the corect battery tie down first, thaanks guys
Old Aug 23, 2008 | 11:06 AM
aim4squirrels's Avatar
aim4squirrels
thanks for posting the resolution!
