1999 Dodge Ram 1500
Old Aug 24, 2008 | 11:01 PM
dothedeww's Avatar
dothedeww
Default 1999 Dodge Ram 1500
99 ram 1500 4x4
5.2
plenum just replaced in june
The trucks been acting funny lately...not speeding up anymore past 4000 rpms...
Thought it was a tranny
but then today, i was driving down the road, and engined just revved and check engine like flashed.
checked teh codes, multiple/random cylinder misfires. Checked twice and all 8 were misfiring at some point.
cant get it above 2500 RPMs or itll just stutter and check engine light will flash.
Any other ideas?
99,917 miles on it now
60,000 pulling horse trailers.
cat's been tested...whole exhaust system is in good shape.
New plugs/wires/cap.
new tranny filter/gasket
any ideas?
after replacing the tranny filter, got it out on the road again to test it...same results past 3000rpms, but its misfiring cylinders 4 and 7 the most...
Old Aug 24, 2008 | 11:48 PM
rabbler's Avatar
rabbler
Check your Fuel Pressure. Should be around 50 Psi.
Is it possible you got a tank of crappy gas and it plugged your injectors?
Old Aug 25, 2008 | 12:07 AM
dothedeww's Avatar
dothedeww
how do I check fuel pressur?
Old Aug 25, 2008 | 12:18 AM
dothedeww's Avatar
dothedeww
The other issue if that it only does it in gear.
Nuetral and Park dont have any problems. Could that still be a fuel filter/pump issue
Old Aug 25, 2008 | 03:20 PM
rabbler's Avatar
rabbler
You need a fuel pressure gauge.
It screws on to a test port on the fuel rail.
You might be able to borrow one from your local parts store.
Old Aug 25, 2008 | 04:58 PM
timberjack's Avatar
timberjack
Junior Member
the same exact thing happend to my 99 ram (5.9) this weekend.let me know if you find anything and i'll do the same
Old Aug 25, 2008 | 06:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the fuel pressure, and also have the cat. checked.
Old Aug 25, 2008 | 09:01 PM
babyhuey6810's Avatar
babyhuey6810
Sure sounds like a plugged cat.How did you check it?Delta test?
Old Aug 26, 2008 | 01:29 AM
megamichie's Avatar
megamichie
Junior Member
Might be computer mlfcn. Almost sounds electrical.
