Help with 9.25 LSD Rearend
Old Aug 26, 2008 | 10:47 AM
sunbird's Avatar
sunbird
New Member
Angry Help with 9.25 LSD Rearend
I have a 9.25 LSD rearend it is in a Durango but there all the same and more people use the truck forms. I replaced the pinion bearing and when changing the fluids found the clutch pack clips in the bottom of the diff verry common I guess. I also found a piece of clutch pack. Now my question is I don't realy need the lsd so what would be the cheapest way to have this rearend reliable. Could I just take the clutch pack out or what else could I do? I took all the pieces out and filled her back up with gear oil and even added the addative and it has been working fine the lsd even still works. I just want it to be reliable!
Old Aug 26, 2008 | 11:50 AM
Medicus's Avatar
Medicus
Cool
I put a detroit true trax in mine it was only about $20-$30 more than the factory replacement. It works great no problems yet. a lot of my friends had them and beat the **** out of it and nothing happened. It locks out the rear end under torque when you want it but it acts like a LSD in turns. it is perfect
Old Sep 2, 2008 | 02:24 PM
sunbird's Avatar
sunbird
New Member
Is there a way of just making my lsd an open diff without swaping the whole thing. I just don't want the clutches breaking more pieces off.
Old Sep 2, 2008 | 02:34 PM
hometheaterman's Avatar
hometheaterman
Swap the carrier out for an open carrier. You can usually find them used pretty cheap. Just ask 01DodgeRam360. He did this same thing.
Old Sep 3, 2008 | 07:10 PM
MO-POWERED's Avatar
MO-POWERED
Default 9.25 diff issues
The clip package from the dealer (Me) is only $9.25 retail... part #5183722ab Why would you waste time and $$ for an open/ one legger rear diff??
