Freeze Plugs
Old Aug 27, 2008 | 02:18 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default Freeze Plugs
I just found out one of my freeze plugs was leaking. One of my friends said that you have to hammer the old freeze plug into the block and then just hammer the new one in, is this correct? If not what is the proper way to install them?
Old Aug 28, 2008 | 07:11 AM
dhvaughan's Avatar
dhvaughan
well.... that's one way, but i don't like the idea of the old freeze plug floating around inside the block and potentially clogging up a water jacket somewhere.
better.... if you can get a punch or screwdriver into position and either punch holes in it, and/or dent the rim in several places, then grab it with a pair of pliers and pull it out.
Old Aug 28, 2008 | 06:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And clean the hole and put some permatex indian head gasket maker around the hole(brown sticky stuff) . Start it with a hammer gently, then use a socket or something with the same radius and tap in to same depth as the old one.
Old Aug 29, 2008 | 12:20 AM
Zeppelinrocks
Thanks for the tips gona get this done this weekend, i didn't like the idea of having the plug staying in my block.
