Offset ball joint questions
Old Aug 27, 2008 | 11:27 AM
994x4durango's Avatar
994x4durango
Default Offset ball joint questions
Need to now what kind i should get and how many degrees it should be its on a 96 4x4 ram. Any help would be much appreciated thanks.
Old Aug 27, 2008 | 06:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I used MOOG on mine and set them at 1 degree negative camber. How bad are they out? If you go to far you will bind the right front shaft where it meets the intermediate shaft and destroy the bushing that connects them.
Old Aug 28, 2008 | 12:18 PM
994x4durango
It looks like i jumped and its not to bad but it is wearing out the insid of the tires bad. The tires need to have positive camber and not negative though.
Old Aug 28, 2008 | 06:00 PM
zman17's Avatar
zman17
0 to 1 degree is fine. My tires used to do the same thing before I used the adjustable joints. That and rotating the tires regularly has solved my tire wear issue. But like I said if you have to bring the bottom of the right side in a lot, it will pinch the two axle shafts together too much.
