Engine oil temp and vacuum gauge?
Old Aug 27, 2008 | 04:52 PM
theviper90210's Avatar
theviper90210
Default Engine oil temp and vacuum gauge?
Hey guys I will be installing a Engine oil temp and vacuum autometer gauges, anybody have any ideas on where and how to install these too gauges into my 2000 ram 5.7l v8. Thanks guys, I will also have a tranny gauge but I have that all figured out already, just need help with the oil temp and the vacuum.
Old Aug 28, 2008 | 06:22 AM
HankL's Avatar
HankL
there are a number of single dual and tripple gauge mounts available
http://www.genosgarage.com/searchprods.asp
I tend to like the pillar mounts
but I do admit that the Dodge pillar is already so wide
that it is a safety hazard
vacuum gauge article
http://web.archive.org/web/200207260...082001_05.html
equations to figure how much HP you are losing when vacuum or exhaust backpressure is too high:
http://www.iprocessmart.com/techsmart/formulas.htm
Old Aug 28, 2008 | 10:40 AM
theviper90210
Thanks I will be mounting them in the a-pillar, what I ment was where to mount and how to mount the sensors to the engine. for the Oil Temp and the vacuum.
Old Aug 29, 2008 | 10:59 AM
theviper90210
btt guys need some advice, plan to work on it this weekend
Old Aug 30, 2008 | 06:16 AM
HankL's Avatar
HankL
the cheap way to mount an oil temperature gauge is to make a T between the factory oil pressure switch for the sensor to mount to,
but I don't like this because you are not measuring the temperature of 'flowing' oil.
A better way is a 'sandwitch adapter' at the oil filter flange:
http://www.glowshiftdirect.com/oil-filter-adapters.aspx
but it is more expensive.
Pick up the vacuum signal at the test nipple on the intake manifold
so as to avoid the check valves in the factory vacuum lines.
Good luck
Old Aug 30, 2008 | 11:03 AM
theviper90210
HankL - Thanks for the idea for the vacuum, ill look into that. Now I have heard of people putting the oil temp in the pan, or through a taped oil plug?? What else do yall think I want to work on this today.
Old Aug 30, 2008 | 11:10 AM
aim4squirrels's Avatar
aim4squirrels
I think I've seen sensors that replace the oil plug, but I've been leary of that since it's so low on the pan that I wouldn't want the wire nicked by under truck debris. I really don't like the idea of tapping the pan directly as you just can't afford to spring a leak.
The part that HankL posted is a good quality part. You can hook the pillar pods up, run the wire through and just wait until next weekend and wire it up. It'll cost you about the time of one oil change, you can reuse your oil if you catch it all in a clean drip pan.
Old Aug 31, 2008 | 07:09 PM
theviper90210
Well i talked to a guy I know at 4 wheel parts yesterday, who is a dodge guy. He said, for the oil temp, i could T it in with the oil pressure sending unit by the distributor. Then for the vac i could put it on one of the test ports on the manifold (like yall said). How does this sound to yall?
Old Sep 1, 2008 | 11:20 AM
theviper90210
Old Sep 1, 2008 | 12:18 PM
hometheaterman's Avatar
hometheaterman
Wasn't that all said above?
