high idle
Old Aug 29, 2008 | 11:08 PM
DBG's Avatar
DBG
Question high idle
Ok, so today i degreased the motor as i have done numerous times before. Problem this time is afterwards when i start the truck it revs right up to 2500 then slowly drops to 1200 and sits there for a little while then drops down to about 700 but it takes a long time to get back down there. any ideas?
Old Aug 29, 2008 | 11:32 PM
pcfixerpro's Avatar
pcfixerpro
I had my key in the on position while i was working on my truck (if you have the driver door open, the key in the on position makes it not "ding") I was wiring up my lights on my pushbar and attached my power wire into the black box under the hood. I undid that nut that the positive battery cable runs to and in the process of trying to put my hoop connector for my lights on the stud, the battery cable lifted off and arc'd. It killed my IAC motor and caused my idle to say at 1200 rpm when in drive. My never went lower than that lol. I replaced it and it works like its supposed to. The IAC motor thats in teh back of the throttle body is in charge of idle so taht would be my first guess.
Old Aug 30, 2008 | 10:47 AM
dhvaughan's Avatar
dhvaughan
if this problem started only after the motor clean/degrease, i'd try to clean the IAC and TPS electrical connector before replacing parts. remove connectors, spray with a little elec cleaner or degreaser or wd40, then apply some di-electric grease and reconnect. reset the pcm by disconnecting neg battery cable and turning key to start for about 30 sec.
Old Aug 30, 2008 | 10:58 AM
aim4squirrels's Avatar
aim4squirrels
+1 don't replace parts until you know they're done.
I have a problem that I thought was the IAC because the idle wouldn't calm down as quick as I thought it should. When I drove it, I noticed the same thing was happening when I let off the gas to brake. The rpms were hanging and it made braking more difficult because the throttle was still pushing the truck forward.
Turned out to be the TPS, not the IAC. I'd test drive it (carefully and away from others) to verify.
Next time disconnect the battery when you degrease the bay.
Old Aug 30, 2008 | 11:19 AM
IndyRamMan's Avatar
IndyRamMan
oh ****....you broke your motor. guess you better buy a new one!
tps iac. check voltage
Old Aug 30, 2008 | 04:00 PM
Mudbone25's Avatar
Mudbone25
deffinatly test voltage. TPS should sweep from just over 1 up to 5 when opening the throttle. TPS was my problem too.
