Blown Fuse and Headlights
Old Aug 30, 2008 | 12:59 AM
jsnpttsbrgh's Avatar
jsnpttsbrgh
New Member
Default Blown Fuse and Headlights
First off the truck is a 1996 Ram 1500 v8.
I have replaced the headlight switch, the dimmer switch and the fuse.
I get no low beam headlights. when I do have highbeam headlights it works for awhile till the fuse gets hot then it blows. Then I lose all headlights and brake lights.
I'm at my wits end with this problem. If anyone can help with this problem that would be awsome. Thanks
Old Aug 30, 2008 | 01:22 AM
jasonw's Avatar
jasonw
Site Moderator
What fuse are you using with the headlamps? Should be one 15A fuse per side, I believe.
Maybe its time for rewiring your headlights using relays to take the load of those switches and fuses.
https://dodgeforum.com/forum/2nd-gen-ram-tech/171606-headlamp-relay-write-up.html
