How Much Fluid Does My Tranny Take
Old Aug 31, 2008 | 08:39 PM
Bob5151's Avatar
Bob5151
Default How Much Fluid Does My Tranny Take
If I drop the pan to change the fluid and filter (I'm not pumping anything out of the converter or anything, just dropping the pan), how much fluid should I buy to replace it? And I should only get ATF+4, which I believe they sell at Wal-Mart now, in addition to the dealer? Any help is greatly appreciated!
Old Aug 31, 2008 | 09:10 PM
MonteC's Avatar
MonteC
5 or 6 quarts. Really what i do is dump in fluid and check it on the dipstick, then once it reads ok, i start up the vehicle, and check the dipstick again, add until it reads ok. Then i run it in move the shifter into every gear for 3 seconds and check it again, add fluid as necessary. THEN i drive it down the road get it nice and hot and check the fluid AGAIN!
Proper fluid level is critical.
Old Aug 31, 2008 | 09:16 PM
padodgeram's Avatar
padodgeram
4-6 QTS , 4 to start and do what the other poster said , always check when hot and in (N) with the E brake on...
