Daytime running lights...
Old Sep 3, 2008 | 07:58 PM
amkuntz's Avatar
amkuntz
New Member
Default Daytime running lights...
We have a 98 3500 diesel dually that has a bizarre problem with the DRL. They quit working and we discovered the fuse had burned out and when we replaced it, the lights came on even though the truck was turned off and the keys were out of the ignition...they won't shut off until we pull the fuse. The lights work fine otherwise, what are we missing?
Marilyn
Old Sep 3, 2008 | 09:14 PM
jasonw's Avatar
jasonw
Site Moderator
You should ask this over in the diesel section, or maybe an admin could move it over there for you. They will probably know a lot more about diesels then we do, as we are mostly gassers here.
Old Sep 4, 2008 | 12:16 AM
amkuntz's Avatar
amkuntz
New Member
Sorry, I'm presuming it is an electrical problem...
Old Sep 4, 2008 | 12:55 AM
jasonw's Avatar
jasonw
Site Moderator
Sorry, I was in a rush earlier today, speed-read the part about "diesel" and skipped to conclusions. My bad. Maybe we can help you out after all, then.
Again, my apologies.
Are there any relays associated with the DRLs that might have "blown" as well as the fuse, and are now stuck on?
Old Sep 4, 2008 | 02:50 AM
rabbler's Avatar
rabbler
Your Daytime running light module shorted out.
Very common on Canadian vehicles.
Old Sep 4, 2008 | 07:25 AM
dhvaughan's Avatar
dhvaughan
i'll ask the obvious question where is the DRL module located and what does it look like?
Old Sep 4, 2008 | 01:26 PM
rabbler's Avatar
rabbler
It's a 3x3" Black square box.
It's usually under the hood mounted on the Driver side inner fender.
US vehicles usually don't even have the connector to plug it in.
