Stereo connector pinout
Old Sep 4, 2008 | 09:10 PM
94Beater's Avatar
94Beater
Smile Stereo connector pinout
I'm in the process of wiring new system in.
I need color code for the stock connectors (there is 2) on the back of the dash unit.
Thanks guys
Old Sep 4, 2008 | 09:15 PM
hometheaterman's Avatar
hometheaterman
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
Honestly though man you would be way better off to get a harness from circuit city, crutchfield, best buy, one of the many places that sell them. Walmart I Think even has some and just wire that to the h/u's harness then plug it into the vehicle. I don't like the idea of cutting up the factory wires so I think you'd be better to spend then $15-20 on a harness. Maybe I'm misunderstanding what you doing though.
bad venge's Avatar
bad venge
Section Moderator
Constant - 12V+ Red
Switched - 12V+ Blue
Ground - Black/Yellow
Illumination - n/a
Dimmer - Green/Yellow
Antenna - Left Rear
Left - Front (+) White/Blue
Left - Front (-) Black/Blue
Right - Front (+) White/Red
Right - Front (-) Black/Red
Left - Rear (+) Yellow/Blue
Left - Rear (-) Gray/Blue
Right - Rear (+) Yellow/Red
Right - Rear (-) Gray/Red
Old Sep 4, 2008 | 09:21 PM
94Beater's Avatar
94Beater
I'm really just wiring some new speakers so all I had to confirm is + and - for the speakers.
Thank you again
Old Sep 4, 2008 | 09:38 PM
94Beater's Avatar
94Beater
I just checked and I do not have wire colors provided.
Its a 94 so some of the wiring might be different.
I got on both sides one wire solid and one with a stripe.
How would it be??
Solid + and stripe - or opposite????
Old Sep 4, 2008 | 09:39 PM
hometheaterman
What colors are they?
Old Sep 4, 2008 | 09:40 PM
hometheaterman
I would suspect the one with the stripe is the - and the one with the solid color is the + however I can't confirm that for 100% so take this with a grain of salt. If anything gets messed up I'm not responsible.
Old Sep 4, 2008 | 09:53 PM
Trey318's Avatar
Trey318
Worst comes to worst, test it on the speaker both ways. There is a noticeable difference in the way the speaker will beat. It will sound funny and it will beat in the opposite direction if its wrong, if I remember correctly.
Old Sep 4, 2008 | 09:54 PM
94Beater's Avatar
94Beater
Right side solid purple and blue w/orange stripe
Left side solid green and brown w/red stripe
