this is prolly easy but ....
Old Sep 7, 2008 | 07:03 PM
BadHab1t's Avatar
BadHab1t
Default this is prolly easy but ....
ill ask anyway where is my fuel filter on my non deisel truck there is a diy for deisels only i need to replace this tomorrow with my plugs tahnx guys i know its a no brainer but y not ask and help out others....j
Old Sep 7, 2008 | 07:20 PM
pcfixerpro's Avatar
pcfixerpro
As far as i know, its in the fuel pump itself (in the tank). Im not sure if you can clean the filter by itself. It would probably be an ordeal and a half. its probably easier just to replace the whole fuel pump, but thats like 300 dollars. If you do replace the filter, do us a favor and fix us up with a diy.
Old Sep 7, 2008 | 07:56 PM
dillonjm's Avatar
dillonjm
In their infinite wisdom, the engineers at Dodge decided a while back to not put a changeable filter in-line between the tank and engine. The only 'filter' we have is located in the tank in the form of a strainer.
If I remember correctly, the ones in our trucks are also part of the pump unit itself and not replaceable individually, but I'm not 100% on that.
Old Sep 7, 2008 | 10:00 PM
jasonw's Avatar
jasonw
Site Moderator
I think they are changeable, as I believe my father's 1994 Dodge Dakota had it changed once (and he has the pump inside his tank).
Old Sep 8, 2008 | 05:51 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Besides the strainer, the pressure regulator also is a filter. It sits on top of the fuel pump.Outside the tank. So technically it is replaceable .
Old Sep 8, 2008 | 10:01 AM
rabbler's Avatar
rabbler
Correct!
Fuel regulator is also the filter.
It is replaceable but quite expensive (Abt $100).
I've never been able to find an aftermarket one and don't expect the dealer to stock the part.
