I just installed a autometer vacuum gauge, using a tee right out of the passenger side of the intake before the check valves, what is the normal vacuum for a 2000 dodge ram 5.9l? Thanks guys just let me know what yall think.
A fluttering needle indicates leaking valves.
The needle should drop instantly when you go WOT if it hangs or slowly drops it can indicate a restricted exhaust (converter)
