I first thought is the computer needs to be programmed to run with the supercharger. I'm not sure what work you have done to the computer but is sounds like a tuning issue.
don't you have to tune your pcm with a tuner? your doesn't it come with something to tell the computer that is runing a supercharger? did you reset the computer? I think RM-INDY will know something to help you
Ya, the computer must be going insane 'cause of lack of vacuum (no? yes?) I strongly recommend a reflash. The stock tuning can't even handle it's own potential, and a cheaper tuner can't reprogram for a cam, let alone a super.
Get an SCT tuner. By tune i dont mean a reset.You need a complete system tune to handle your blower. Cam, timing, psi, fuel injection..etc all have to be calculated and tuned for your blower to work at its maximum.
