Front coils
Old Sep 12, 2008 | 03:24 PM
Littenracing's Avatar
Littenracing
Default Front coils
Has anyone put coil spacers in the front of a 2wd 2500?
I'm talking the round rubber one's that go in the control arm pocket.
I'm looking for a 1.5 to 2 inch lift.
Old Sep 12, 2008 | 03:53 PM
dodgeguy97's Avatar
dodgeguy97
are you try to lift the whole truck or just level out the front skyjacker and rough country all those four wheel site's make leveling kits and or lift kits. but yes i have used those rubber coil spring spacers and they work fine
Old Sep 12, 2008 | 04:04 PM
dodgeforlife15's Avatar
dodgeforlife15
i have some in my 2wd 1500. they say it raises the front end 2 inches but it only lifted mine about an inch. they do work great though.
Old Sep 12, 2008 | 07:16 PM
Kindschi's Avatar
Kindschi
Are you needing some? I have a pair (2inch I beleave) that I got just in case I needed them to fit my wheels, and I don't need them now. If your interested let me know.
Old Sep 14, 2008 | 05:36 PM
Littenracing
I have a 2wd. Are they the same on a 4x4? I'm intrested in them if they will work on my truck. I want to lift it a inch or two.
My truck is a 01 2500 2wd.
Old Sep 14, 2008 | 06:45 PM
dodgeram07's Avatar
dodgeram07
"Are they the same on a 4x4?" i think that the 4x4 bolt into place and the 2wd sit on top..i think
dodgeforlife15 " they say it raises the front end 2 inches but it only lifted mine about an inch" is that because of the weight "Westin Brush Guard" ??
Old Sep 14, 2008 | 06:52 PM
Kindschi's Avatar
Kindschi
Ill dig them up and post a picture and let the other dodge gurus on here say if they will or will not work, I just dont know.
Old Sep 14, 2008 | 06:59 PM
dodgeram07's Avatar
dodgeram07
2wd http://www.suspensionconnection.com/...C09103D16.html
4x4 http://www.suspensionconnection.com/...on/329005.html
maybe if they have bolts you can take them out if they are not need ..maybe
Old Sep 15, 2008 | 01:20 AM
dodgeforlife15
i thought that my brush guard may have been the reason, but i have taken the guard off and it only makes about 1/4 to 1/2 inch difference in the ride height. you could see the spacers were only about 1.5 inches thick anyway.
Old Sep 15, 2008 | 11:23 AM
Littenracing
Ive lifted a 2wd drive before. and they do just sit on the spring. I put them on the bottom. But im not sure about the 4x4.
