oversize tires
Old Mar 4, 2005 | 01:13 AM
  #21
97jackedup's Avatar
97jackedup
Default RE: oversize tires
I run 35's and my speedometer reads the correct speed. Kinda wierd I know. MPG dropped about 2mpgs after lift and tires. Rim "Offset" or backspacing is critical in fitting tires to your truck. The rams look hot with 33's or bigger.
Old Mar 4, 2005 | 02:51 PM
  #22
hometheaterman's Avatar
hometheaterman
Ok I have a question since the offroad package is 2" higher when you put a 3" lift is it only 1" higher than it was or is it 3" higher so total lift of 5"?
Old Mar 4, 2005 | 03:00 PM
  #23
97jackedup's Avatar
97jackedup
The offroad package isn't really considered a lift since its stock, technically you would be riding about 5inches higher than a stock ram1500 4x4 non-offroad package. From what i've seen it isnt real easy to get lifts for trucks with the offroad package
Old Mar 5, 2005 | 01:52 AM
  #24
hometheaterman
Oh ok I have the offroad package and also have a Skyjacker lift but never looked for one as it was on the truck when I got it.
Old Mar 7, 2005 | 02:37 AM
  #25
hipkinsd's Avatar
hipkinsd
ORIGINAL: Danko
Congrats on realizing the Rams look ridiculous w/o taller tires, especially the 4 x 4's. When you figure your mileage, remember if your speedo is underreading 5%, so is your mileage computation so you are doing a little better than you figured initially? To learn a lot about tires including diameters and a lot more including survey and test results, go to www.tirerack.com and plug in a tire size and then click on specs and scroll around and you will see the diameters and more of a lot of sizes including the one you are considering. Then remember if your stock tire is 28" and you move to a 31" when your speedo says 28 or 56 you are really doing 31 or 62. Easy to figure and not worth correcting the speedo for. This also stretches your warranty period out because if your speedo underreads by 5% you will get 5% more miles on the truck before your warranty mileage is reached. Fun, huh? Something else about going to a bigger and wider tire that not many people think about until they make a right turn and their right rear wheel gets scratched by hitting a curb........ pushing the wheel up and sticking the tires out farther protect the wheels from damage. I am surprised with the big wheelwell openings on the Ram that 285's could rub. A guy with a Ford 4 x 4 was over here and he had 315/75 x 17's on it w/o any suspension change but it was a 3/4 ton and therefore might sit higher. Even though, those tires are a couple inches bigger in diameter than the 285/16's.
This is all exactly right. I went to 285's on my stock 4x4. I do get a slight bit of rubbing when I cut the wheels all the way in either direction. Wheel spacers would solve that problem and they're cheaper than a lift or levelers. You might find a pair at a salvage yard.
Old Jun 14, 2007 | 04:31 AM
  #26
rellegib's Avatar
rellegib
I have the Yokohama Geolander 285/75-16 on aftermarket American Racing wheels and have no rubbing whatsoever. It does look so much better than the stock 4x4.
How can I tell is I have the off-road package since I bought the truck used? It's a Laramie SLT with a 5.9L
Old Jun 14, 2007 | 08:30 PM
  #27
JarheadX's Avatar
JarheadX
I got 33's...i love em, i got no rub, my speedo is off by 5, and my gas is still bad, idk what it is exactly..and i don't want to.
