Is this a 5.2 or 5.9?
Old Sep 18, 2008 | 02:02 PM
ophidia's Avatar
ophidia
Default Is this a 5.2 or 5.9?
I am in the process of buying a 1999 Ram 1500. The dealer doesn't know which engine it has in it, and I don't see any external markings on it that says. Is there any easy way to tell which it has (5.2 or 5.9)? It has plenty of power.
Thanks!
Old Sep 18, 2008 | 02:18 PM
liljoe's Avatar
liljoe
the 8th digit on the vin tells you the engine size or open the hood and on the radiator support bar there should be a tag that has all that infomation on it
Old Sep 18, 2008 | 04:34 PM
HankL's Avatar
HankL
Thanks!
crawl under the engine compartment and either look or feel the balancer pulley combination attached to the engine shaft.
A 5.9 V8 has a cut out in this balancer, so it is not smooth all the way around.
This is because the long stroke 5.9V8 is 'externally balanced'
while the smaller stroke 5.2V8 is internally balanced
Old Sep 18, 2008 | 07:13 PM
dhvaughan's Avatar
dhvaughan
not much of a dealer. don't count on future support.
Old Sep 18, 2008 | 07:23 PM
Crabman's Avatar
Crabman
Pull the heads off, measure the piston displacement and multiply by eight.
Old Sep 18, 2008 | 10:19 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
"X" for 239
"T" for 318 CNG
"Y" for 318 gas
"Z" for 360
"5" for HD 360
"W" for 488
"C" for 12 valve Cummins
"6" for 24 valve Cummins
"7" for 24 valve HO Cummins
Old Sep 19, 2008 | 12:52 AM
ophidia's Avatar
ophidia
Based on what it said on the radiator support, it's a 5.9l. Fun times.
Thanks all
Old Sep 19, 2008 | 12:41 PM
Trey318's Avatar
Trey318
lol. Nice.
