Tranny shifting points
Old Sep 23, 2008 | 05:18 PM
tazman6789's Avatar
tazman6789
Default Tranny shifting points
Ok so i have a hypertech programmer on the way thanks to talon6. Ive read on here somewhere that you cant change the shift points on the 46re. Is this true? Reason im asking is because i had the transmission rebuilt like 8-9 months ago, and ever sense its been back to the same shop like 4 times cause it didnt get done right and never shifted right. first time the valve body went bad, second time it was leaking (didnt get fixed right) 3rd time torque converter fixed the leak, now 4th time cause its not shifting right, at about 30 mph i let off the gas and instead of coasting for a while it feels like ive downshifted in a manual tranny. the rpms go up and u can feel it engine braking, the tranny has no coasting ability whatsoever even on a down hill u can fell the enginebraking the truck. And the shift between 2nd and 3rd is hard, and when it downshifts from 3rd to second it engine brakes really bad. I want to adjust the shift from second to third to be a little bit lower so when im cruising the city at 35-40 its not bouncing between gears so many times and f-in up my tranny more. eventually i have to take it back to the shop to get it fixed im just sick of not having my truck for weeks at a time.
Old Sep 23, 2008 | 05:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Any chance you live in New England and had NE tranny fix it? LOL You'll know what I mean when you the see the upcoming posts.
Anyway, check out the TV cable adjustment just for sh--ts and gi--ggles If you have a Haynes manual it's in there. BTW, Which Hypertech did you get? I don't think any of them do shift points. Unless they have something new.
Old Sep 23, 2008 | 06:07 PM
dillonjm's Avatar
dillonjm
No, the Hypertech does not adjust the shift points.
Old Sep 23, 2008 | 09:55 PM
MonteC's Avatar
MonteC
Wow, sounds like they screwed something up royally.
Old Sep 23, 2008 | 10:10 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Wow, am I the only one here with a decent rebuild (*knock on wood*)
Old Sep 23, 2008 | 10:12 PM
Jr. Mechanic's Avatar
Jr. Mechanic
No, ive seen plenty, but for some reason some people cannot get it right...
Old Sep 23, 2008 | 10:13 PM
2000ram1500's Avatar
2000ram1500
i got a decent one a while ago.
Old Sep 24, 2008 | 06:10 AM
MonteC's Avatar
MonteC
Its a shame, alot of these "shops" just crack open the drums, throw in a couple of frictions, spray parts off with brake cleaner and put them back together usually with impact guns. Charge the customer 2k and hope and pray that it works. Then when it doesnt they give the customer the run around until the customer is tired of dealing with the "shop".
Old Sep 24, 2008 | 05:57 PM
tazman6789's Avatar
tazman6789
The Most Powerful Tuning You Can Buy!
The Max Energy Power Programmer extracts every bit of energy possible out of every molecule of fuel giving you more mpg at part throttle and more power at wide open throttle. All this and more... Only from Hypertech!
Maximum Horsepower & Torque
Improved Fuel Economy
Raise Top Speed Limiter
Raise "RPM" Rev Limiter
Adjust Shift Points & Firmness <<<<<<<<<<<<
Recalibrate Speedometer
Lower Cooling Fan On/Off Temps
Read, Display and Clear DTCs
Internet Updateable (USB included)
50-State Emissions Legal
Easy Plug-And-Play Installation
Copied right from hypertech page i got the max energy one. Yeah most places are a sham, this guy is a chrysler master tech thats why i took it to him. Friend of mine got his done somewhere else same time i did and he tows a huge trailer everyweekend and he hasnt had a single problem with his.
Old Sep 24, 2008 | 06:04 PM
zman17's Avatar
zman17
OK, you still need to check the TV cable and make sure it's properly adjusted (as close as it can be without a pressure gauge) before you go messing with a tuner.
