overhead console
Old Oct 1, 2008 | 11:18 PM
Metal King 8989's Avatar
Metal King 8989
Originally Posted by APA228
The temperature sensor is separate from the unit mounted under the hood, the compass is self contained. The '96 did not come with the MPG feeds, but the later trucks did have it. It is fed from a feed from the Central Timer Module.
i have a 96 that would explain the lack of mpg reader. my apologies for false information
Old Oct 1, 2008 | 11:22 PM
PurplDodge's Avatar
PurplDodge
I figured that some thang would be different because you have a 96. Now i need to find the Central Timer Module.
Old Oct 2, 2008 | 03:39 PM
PurplDodge's Avatar
PurplDodge
/bump
Old Oct 2, 2008 | 05:39 PM
APA228's Avatar
APA228
According to my copy of the 94-01 factory service manual it is located on the left side of the steering wheel opening below the instrument panel.
Old Oct 2, 2008 | 08:33 PM
PurplDodge's Avatar
PurplDodge
and what color wire is the feed?
Old Oct 2, 2008 | 10:37 PM
APA228's Avatar
APA228
PM me your e-mail, I will send copies of the wiring diagrams to you. There are several wires running to the unit in the later model trucks. tom_gonzalez@verizon.net
Old Oct 6, 2008 | 06:08 PM
PurplDodge's Avatar
PurplDodge
does the sensor look like these?http://www.rockauto.com/catalog/rafr...1377569k944283
Old Oct 6, 2008 | 06:26 PM
APA228's Avatar
APA228
The sensor looks similar to the AIRTEX Part # 5S1136. You will need the socket setup with this one. 2 wire socket to fit male plug on the sensor.
Old Oct 6, 2008 | 06:42 PM
PurplDodge's Avatar
PurplDodge
i just sent you an email
Old Oct 17, 2012 | 09:01 PM
purkl dodger's Avatar
purkl dodger
New Member
Default overhead console
i am looking into seeing if i can change my overhead console. i have a 98 dodge ram and the console that i took out of another truck is out of a 99 has the two storage compartments one for a garage door opener and one for sunglasses. also the digital display. is this doable or am i going to be chasing my tail.
