Is my Tranny starting to go?
Old Sep 25, 2008 | 01:31 PM
RamWood's Avatar
RamWood
Default Is my Tranny starting to go?
When driving the truck on the interstate (70 mph) and I get to a hill. Fist off, it seems to want to kick out of OD a lot more then any other vehicle I have owned. Then when the hill flattens and even starts to go DOWN hill it seems to take a couple of seconds for the OD to kick back in.
I can just push the "decel" button on the cruise and it will go into OD right away.
Probably nothing but just wanted to know if anyone else had a similar problem.
Old Sep 25, 2008 | 05:59 PM
tboss's Avatar
tboss
You didnt say whether you are driving with cruise control on or off. If it works dont mess with it. It will let you know when something is going wrong.
Old Sep 25, 2008 | 06:42 PM
pcfixerpro's Avatar
pcfixerpro
Probably not. Your probably like me and have 3.55's I seem to lack top end power... well shoot... lack all power lol. But I know what your saying. My truck was like that before and after the tranny rebuild.
Old Sep 25, 2008 | 08:24 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
You have a second Gen Ram?
You have a 50% chance that your tranny is going at all times.
Jk, lol. 2nd gen rocks.
Old Sep 25, 2008 | 08:28 PM
pcfixerpro's Avatar
pcfixerpro
Lol, best response i've ever heard
Old Sep 25, 2008 | 08:49 PM
dhvaughan's Avatar
dhvaughan
a bad throttle position sensor TPS can cause a lot of excessive downshifting. mine was doing that before i replaced it. its a lot better with a new one, about $40-50 at any parts store.
when it doesn't upshift, its related to the throttle and TV cable adjustment. i'd replace tps first and see if that fixes both problems. it could be a false problem where the cruise is just pushing the gas too hard.
Old Sep 26, 2008 | 10:06 AM
RamWood's Avatar
RamWood
yes this is with cruise on
Old Sep 26, 2008 | 10:07 AM
RamWood's Avatar
RamWood
I thought that the TPS could cause the "surging" I don't get any of that.
RamWood's Avatar
RamWood
yes I do believe that I have the 3.55
Old Sep 26, 2008 | 10:15 AM
HankL's Avatar
HankL
check leaks in the vacuum system lines that feed cruise control under battery
if you can borrow a OBD scanner
look at the voltage signals for
TPS
MAP
for extreme 'jumping around'
while on cruise control,
then repeat using a 'smooth foot' on the accelerator pedal
instead of cruise control
(but the O2 sensor should jump around)
also check the accuracy of the speedometer
against either highway mileposts or GPS
because the cruise control computer programming does different things
depending on actual MPH
it is common for old/high mileage TPS to go bad at a certain spot in its range
good luck
