lowering question
Old Sep 26, 2008 | 12:36 AM
dakotas ram's Avatar
dakotas ram
Default lowering question
can i use "2 coils in the front and still be able to get it aligned?
Old Oct 2, 2008 | 06:10 PM
MO-POWERED's Avatar
MO-POWERED
Yes.. shouldn't be a problem at all.. When you go to 3" drop coil spring is where alignments need some extra time.. (upper a-arm alignment slots need to be slotted bigger with the use of carbide bit, or rasp for more alignment adjustment..) I'm in the process of going 5" in the front with the use of 3" spring and DJM 2"arm combo..
