Sick 360, Please Help
Old Sep 29, 2008 | 07:58 AM
sapperpage's Avatar
sapperpage
Default Sick 360, Please Help
I have a 96 Ram 4x4 with a 5.9 that needs some help. Several weeks ago I was driving to town and I noticed my truck started to lose power and run a little rough like it was firing on 6 or 7 cylinders. Before I could get home it was horrible and when the truck would shift into OD it would shake like nothing I’d ever seen. It also set a code 43 (Peak primary circuit current not achieved with maximum dwell time). I read several post and most believed it was the coil. So to date I’ve replaced the coil, plugs, plug wires, dist cap, rotor button, and just yesterday I replaced the plenum & intake manifold gasket. I’ve checked all fuel injectors, done a compression test on all cylinders and a vacuum test and everything checks out fine. I’m hoping someone out there may have experienced the same thing and can point me in the right direction.
