speed sensor
Old Oct 2, 2008 | 03:35 AM
dodgies's Avatar
dodgies
Default speed sensor
How do you install a speed sensor on a 2000 Dodge Ram? tnx...
___________
dodgies16543
Old Oct 2, 2008 | 03:42 AM
kurtdaniel's Avatar
kurtdaniel
First, unplug the wire that's attached into it, then unscrew the old sensor and screw the new one back in. Plug the wire back in...that easy,,good luck..
hp?act=post&do=rehp?act=post&do=re
kurt E. daniel gas mileage devices
rum/forumdisplay.php?f=
Old Oct 2, 2008 | 03:45 AM
dodgies's Avatar
dodgies
oh,,i see,,tnx much...
Old Oct 2, 2008 | 07:28 AM
dhvaughan's Avatar
dhvaughan
there's 2 sensors.
the true vehicle speed sensor is in the output of the trans (2wd) or t-case (4wd). its just like said above. its also plastic, so don't overdo the torque.
there's an abs sensor on top of the rear diff that's part of the speedo/abs process. it has an electrical connector and one small bolt. don't drop anything down into the diff.
