help!!!!
Old Oct 5, 2008 | 02:50 PM
thursty_n_hungry's Avatar
thursty_n_hungry
Unhappy help!!!!
ok i just put synthetic oil in my 01 dodge ram
and now when i crank it, it bleeds out the back seal
any help wat do i do
help
help
Old Oct 5, 2008 | 03:00 PM
Viper37's Avatar
Viper37
Seal is shot.
Old Oct 5, 2008 | 03:04 PM
thursty_n_hungry
why do you think it happen though
is the seal just bad or could it be something else
Old Oct 5, 2008 | 04:00 PM
aim4squirrels's Avatar
aim4squirrels
you probably had sludge plugging the leak. the Syn actually breaks up sludge and exposed it. You can fix it yourself, here's a link:
http://www.pavementsucks.com/tech/rearmain.php
It's not that hard, just time consuming. Took me a full day to do. I did do some other stuff at the same time though. I'd give it at least 6 hours to be safe.
Old Oct 5, 2008 | 09:16 PM
rabbler's Avatar
rabbler
Did you just put the oil in or has it been a few hundred/thousand miles since?
Is it possibly leaking from the new oil filter or filter gasket?
Old Oct 5, 2008 | 10:03 PM
MonteC's Avatar
MonteC
Synthetic oil does not bode well with high mileage seals and gaskets.
Old Oct 6, 2008 | 02:21 AM
TIMIDONE's Avatar
TIMIDONE
I've heard that before....I use Royal Purple Full Synthetic...no problem on this side!
Old Oct 6, 2008 | 03:17 AM
jasonw's Avatar
jasonw
Site Moderator
It does not work well sometimes with high mileage. Sometimes there aren't any problems, sometimes there are many leaks all over the place. However, I consider it a maintenance issue. The sludge was plugging up leaks, well now you actually have to fix the leaks, the proper way.
Old Oct 6, 2008 | 07:23 AM
98DodgeRam1500's Avatar
98DodgeRam1500
I wish I could get some sludge to plug up my axle leak.
Old Oct 6, 2008 | 09:47 AM
jasonw's Avatar
jasonw
Site Moderator
98DodgeRam1500, that axle leak is one of things I've decided you can't complain about.
J/K. Sorry for being off-topic, was reading your sig again and had to laugh.
